Stance
mjb765
Does the rear end look too low?? It's 25" from the center of the wheel opening to the ground sitting on 275/60 on 15 X 8 rims. I don't know what the springs are or how old.....so that brings up if I want a bit higher what do I order??
Katfish
Palm Bay, FL
Personal preference, but I hate seeing light between the top of rear tire and fender.
Looks perfect to me.
mjb765
Thanks for the opinions...most of the ones I see look a bit higher.....maybe I'm just nuts...I guess I can throw my money at another part of the car......
If you are going by measurements, ( there isn't a spec the way you are measuring) I bet the front end is too low according to factory ride height specs, so it is really whatever you want it to be as long as you make sure the alignment is correct when you are done with it.
You can have springs made in any rate, and arc height that you specify with the spring companies.
Just need to compensate for the relaxing of the springs after they break in.
A lot of guys here like Espo.
ESPO Springs n Things | Mopar Parts & Services Connection
Nice looking car !
fasjac
Nice looking! Personal preference is slightly up in front and rear. Not much though, like an inch or so. 👍🏻
Juan Veldez
Nampa, Idaho
Looks like the fender trim is aligned with the tires at the same place, just below the top, front and rear. I like it a lot. And VERY nice looking overall ride, BTW.
6PKRTSE
Looks perfect to me. I like them low with big meats in the back, but not lowered/like slammed or air bagged.
6PKRTSE
Mine is a -1" in the rear but I am running 30" tall tires so I wanted to bring it back down to stock ride height.
jeffmopar518
utah
looks good but personally a little more up in the front and rear makes it look a little bit tougher..
Fishgutz
Northern California
Mine sits on MP Superstock springs, rear, and 1.05” torsion bars up front. 17” x 275 x 40 and 17” x 245 x 45 respectively.
I‘m really happy with the look and handling.
Yours looks awesome, don’t change a thing and drive the hell out of ‘er!!!
