498 sure grip.
Avalanche
Massachusetts
Where is the best place to but a complete 489 sure grip?
Dr. Diff only sells the gears and I would like something I can just bolt up.
Also, how do you find out what yoke and spline is in car? It's a 70 challenger and 70 existing cone type rear in it now.
Rich Followell
I have a complete 70 Challenger 489 diff, with 3.55 gears, big brake drums, and e-brake cables. I would like to sell located in Wisconsin.
gzig5
Mequon, WI
I’m pretty sure Dr diff will build you a complete diff with your choice of gear and sure grip on your housing or a new housing. Not sure if he provides an oem housing. Best to call him or email.
pschlosser
Santa Rosa, California
The third-member housing assemblies are not being made, reproduction, as far as I know. While still pretty plentiful, they don't grow on trees. Most axle/machine shops, local and abroad, can correctly assemble it for you, if you get all the parts. Finding another third-member, then ordering the parts (example, from Dr. Diff), and then taking it to a local 4WD shop will be the least costing route to go. It will save you considerable on those shipping fees.
While some garage mechanics are idiots, when it comes to vintage muscle cars, it's not their fault, they lack exposure and experience with these vintages babies. But this third-member stuff, and the skill to assemble it right, is still alive and well on modern-day vehicles and especially with those 4x4 lift shops.
john-9
Dr Diff ,, Mancini Racing for complete center sections -- to determine what spline yoke you have if the pinion nut is 1-1/8 across you have the coarse 10 spline yoke ,,, if the pinion nut is 1-1/4 across you have the fine 29 spline yoke .. you would want the unit built with the correct yoke width to fit your driveshaft small yoke 7260 series is about 3-1/4 inches across ,, large yoke 7290 is about 3-5/8 inches across ,,,. since you have a sure grip center why not have it rebuilt with the gear ratio you want.
Spyder
Far N. California
I bought a Dr. Diff complete third member that bolted right in without any problem earlier this year. Took about 2 weeks from time of order to when it arrived. Highly recommended.
Spyder
Far N. California
Link here: Mopar 8 3/4" (8.75) 489 Case Third Member
Edited: Huh, it does show out of stock on that once you click through and choose all the options. Guess the above suggestion of finding one local and buying the guts and having a shop build it is the next best thing. Glad I ordered mine when I did.
Avalanche
Massachusetts
Thanks for all the replies. I will look into getting mine rebuilt. A new complete center section would cost about $1,800.
Should be cheaper to rebuild.
Rich Followell
What are you asking for it?
Well I was asking $800.00 for it. but some people thought that was to much. It came out of a low mileage Arizona car and was only removed to be replaced with a 9 inch Currie diff. I think you could replace the brake cylinders, and paint it then install it. But I have to ask how would you ship it or would you be willing to drive this far to come and get it?
Oregon AAR
Oregon
Believe it or not, Walmart has new SureGrip 3:55 Yukon 489 drop in units for $1355. The actual vendor is Randys WW. Free shipping.
CudaGapCuda
Molalla, Oregon
Hey Avalanche
Keep in mind that when you have a sure grip rebuilt there are two different shims in the bearing kits the most common that they use has the thicker shims and I went thru two years of a sure grip that was almost a total lockup. After receiving no real good feed back from SixStates (they said find a parking lot and do lots of tight curves until it loosens up) I think they just did not know. I called Dr. Diff and he knew just what I needed he set me up with the right kit and that solved the problem I was ecstatic, I could turn a corner with out wheel hop. I had SixStates swap out, a note to them is they did not charge for the swap but I did pull and delver to them the sure grip pumpkin and payed for the new shim kit.
Avalanche
Massachusetts
Hey Avalanche
Thanks for the heads up.
