Exterior emblems...
Oystercopy
Hey guys.. so I put new emblems on the car about 4 years ago (it had none when I bought it) and one of them imploded on me. It is the R/T symbol I bought new from Year One. At first, I noticed the red insert paint fading, and then the paint itself started to chip off! I couldn't believe it. So I'm contacting them to tell me if they'll replace it for me. Problem is, I don't know how I would even remove this one, since its a stick on, without damaging the paint? Of course, the car doesn't see any sun or other weather, as its only on the road very little during the year. sp this was not exposure related. Anyway, hope this helps someone.
OC
Raycuda
Florida
OC
Do you really think they will replace a 4-year-old emblem?
Oystercopy
Well, I don't know Ray. But if you pay $65 for a cheap knock off like this, somebody should be held liable for it, I would think? I'm sure the OEM emblems didn't fade like this. I could see if it was subjected to adverse conditions, but it was not. Plus, I'll probably have to have a body shop remove the emblem so I could replace it. And if they don't offer to replace it, my only option is to re-paint it again, which I'd rather not do either.
floyd
It’s been years since I dealt with Year One, but they were very good about returns. Worth a shot I suppose. I would think gently warming it up with a heat gun would soften the adhesive enough to be able to pry it off?
Oystercopy
"I’d be pissed"
Yep, anybody should be that pays good money for garbage like that.
gran coupe john
Ohio
Will be restoring my original emblems. The quality of repops from China are garbage. It only cost a few bucks more to have originals restored. The 50+ year old emblems are of great quality, and should last another 50 years once restored. My opinion.
Raycuda
Florida
I really don't think they will refund after 4 years, but I can help with removing the stick-on emblems. Heat the emblem with a hair dryer, then take dental floss and slowly "saw" through the adhesive. You should be able to get the emblem, and most of the adhesive off this way. The remaining adhesive will come off with WD-40 or Goo Gone. A little polish and yoiu are done.
Good luck.
MoparCowboy
Texas
Above reply is spot on. I removed a stick on emblem that was probably applied when the car was repainted in 2004. I didn't even heat it up, and I had fishing line in the shop so used it and went right through the tape. Used goo gone to finish removing glue and residue. Worked great.
Cuda360-4
Reading, PA
Same here. Heat guns always took them off. After reading these I am grateful that I bought original emblems at the dealer in the 1980s. They still look brand new.
Avalanche
Massachusetts
I had a rt grill emblem red paint melt off in the summer. It was about 4-5 years ago. It was from year one. I called them back then and they said they had a bad batch of paint. They just sent me a new one. Been good ever since.
Oystercopy
Update: Year One, after back and forth emails, showing them the defective product and how it failed, refused to replace the emblem, except at a discount. This is fraudulent as it is more than clear that the emblem was/is defective and should never have failed the way it did. I chose to repaint (rather than remove and replace) the emblem and am in the middle of that now. If I could find the correct color red paint, it'll probably look good as new. At least till it falls off the car somewhere, due to the Chinese nature of manufacturing/adhesives. LOL
OC
