1 inch lift on the back
jsand
Indianapolis
Whats the easiest way to get a 1 inch lift on the back suspension? Raising the car 1 inch in the back shows the tire a bit better and gives it a slight rake look.
Vaanth
West Georgia
I have added Pro-Comp 13120 leafs to the rear leaf springs in place of mid-length leaf on two cars with good success. Both lifted about one inch. It could vary depending on the current spring condition.
My original T/A springs had lost a bit, so I added the Pro-Comp leaves to restore it's rear height. Handling seems the same. Adding them for the mid-length spring, I was able to keep the lowest leaf with the factory part numbers.
My GTX was sitting at factory height plus a little with new springs from General Spring. Those were specified as +1" already, but I wanted a little more rake and height to better show the wheels in its short fender openings:
6PKRTSE
I went the opposite. -1" springs and I also added a 1" lowering block welded 100% around. With 30" tall tires I didn't want the jacked up look.
Katfish
Palm Bay, FL
You have a close up pic of the rear window in the TA?
It seems to be tucked down? I don't see the chrome trim?
cuda joe
nj
what springs do you have in now ? if you have the orignal springs definitely go with 1+ new springs
LoneCabbage
Orlando, FL
I recently purchased a set of +1.5" springs from St. Louis Spring Company. They will custom make whatever you want, and I found their prices to be reasonable and their shipping was fast.
