Street car I already have a Edelbrock Performer. Considering aftermarket alum heads, if anything, to get some weight off the nose. I would have both powder coated or painted to match block. Want to end up with a setup that would work with minimum 93 pump gas.Anything 400 block based - 470", 500", 512". Is the stock appearing idea just kinda sorta meaning aluminum heads and intake under a stock air cleaner or does it have to be factory iron heads and intake?
What is the ultimate goal for the engine?
>snip<
A few years ago I built a stroked 383 (438") for a friend of mine. It was a very basic combo as he did not have a big budget. We used a 383 block bored .060" over with very basic machine work. 440 Source rotating assembly and OOTB Stealth heads with Fel Pro .039" gaskets for 9.3:1 C.R. Edelbrock Performer RPM intake. Hughes hydraulic cam HUG SEH2832BL-10 and lifters, Comp Pro Magnum rockers, stock pushrods, Comp double roller timing chain. High pressure oil pump and 440 Source 6 qt. oil pan. Generic headers were used on the dyno but in the car ('66 Fury) he is using TTi 1 7/8" headers and a full TTi 2 1/2" exhaust system. MP distributor and electronic ignition, Taylor wires, Champion plugs. Holley 750 3310 carb.
450hp @ 6,000 rpm and 475 lb. ft of torque.
For the money, stroker kits are the way to go. A lot of your recipe will depend on how deep your pockets are. With all of your engine mods, be sure to also look at the transmission/rear to ensure they work together to get you what you want. I put a 512 stroker (440 block) into my Challenger and use the 727 with 3.23 rear gears on the street.Looking for a stock appearing performance recipe. I know it's not stock appearing, but will be running 1-7/8" headers through stock mufflers and resonators. Would like to retain A/C and ower brakes.
I agree that the 383/496" is a bit too much. The 438" we built was damn near perfect for my friend's application. It went in a C body with a column-shift automatic, a "street hemi" style onverter and highway gears. Runs smooth, produces good vacuum and has a nice rumble with a TTI exhaust system. It is the most power this guy has ever had under his right foot. He drives it around NYC and on the surrounding highways and it does everything he wants it to do and then some. Any more power and it would be downright dangerous as this guy drives like a maniac and the car is an unsafe rust bucket.The best stealth recipe IMO is to stroke to 436 CI , basically a 440 in a low deck block , if you go bigger you start to push the piston pin intto the rings , more of a race combo , but the 436 removes 7 lbs of rotating mass & is abetter build over a RB 440 , I can get a lot of power porting production Iron heads but I agree the TF 240s are superior
The one in the dyno clip I posted was bored .060" over because it wouldn't clean up at any less. We didn't have it sonic checked -again, budget. Definitely not ideal for a race engine but it's what we had to work with.I prefer to bore .040 over or less , the couple of extra CI doesn't outweight the added strength of the cylinder wall
