Carlwalski
Hey folks, I have a Dakota Digital RTX gauge set in my 70 RT, I love it but my fuel gauge is inconsistent. When I fill it up, it shows maybe 88-92% (never really full), I drive 20 mins and it will fluctuate down then up 5-10%, not too bad but not correct either. And when it hits 50% or 1/2, it seems to go WAY too fast vs. the first half. Its just not reading right lol, that I know.
I believe its the ground, gauges all work great in the cluster so I don’t think its JUST the 1 fuel gauge acting up. I have an in tank pump for my EFI system so cut and welded closed the old pickup and return and use it solely for the sender only.
Question: is my current ground (pics attached) a bad setup? I think its too small a gauge? Not enough metal maybe? Tested sender on bench and its perfect ohms. I thought about putting a metal ground crimped on to one of the old sender “nubs” and running that to the chassis?? I can’t use a standard sender ground strap so any ideas that will make the connection SOLID?
Thanks!
Thanks!
