tvanbibber
Tip for the wise, they slip in way easier when you have the left torsion bar on the left and the right bar on the right.
Your only a rookie once, ill never happen again. Lol i was going to tell you there was a left side and a right side, figured you knew that. At least its doneTip for the wise, they slip in way easier when you have the left torsion bar on the left and the right bar on the right.
I knew there was, it's stamped on the ends and still got them on the wrong side. Hard to slow down and you have all these shiny parts ready to go on. Going to all power disc brakes as well from Drums all my life. '72 Challenger 340.Your only a rookie once, ill never happen again. Lol i was going to tell you there was a left side and a right side, figured you knew that. At least its done
Nice im doing a 73 just finished front end rebuildI knew there was, it's stamped on the ends and still got them on the wrong side. Hard to slow down and you have all these shiny parts ready to go on. Going to all power disc brakes as well from Drums all my life. '72 Challenger 340.
Just got done doing rear end also, new springsVery nice, I decided to go with the QA1 Upper, Lower control arms and sway bar as well as new rear leaf springs. This all has been needed for way too many years.
Another time for a rear end, mines been fine since 1972. Here's my car for a visualFinished rearend before doing front, changed out springs, and put a different center section in. That was a first and more detailed than i thought.Setting axle end play wasnt that bad. There are a lot of guys on these boards that give advice and of course youtube
