Got LCA’s back from welding.
Grand Island, NY
I received the LCA’s from welding on the plates, and they came out great!
I had him do the washer trick and will press out the bushing housing today
The rubber bumper is junk and a new one has been ordered.
Any recommendations on a good chemical rust remover?
gzig5
Mequon, WI
White vinegar works good for rust removal and is cheap. Evaporust works well and isn't as cheap.
pschlosser
Santa Rosa, California
most of the rust-removing products indeed, remove rust. As other have said, vinegar, evaporust, navel jelly (and a number of other phosphoric acid products) as does citric acid (my favorite). But I would not recommend pool (muriatic) acid or other sulfuric acid products.
if you want to soak your parts, you may need several gallons of material to cover them in a tub. citric acid may be the most cost-effective way to go. (1.5cup or 400gram citric acid powder) per 1gal water.
Grand Island, NY
Thanks!
EV2RTSE
Looks great! I've been buying Evaporust in 5 gal buckets for my project, I get it with free delivery through Amazon prime (my delivery guy must hate me) but it works well and you can do a surprising number of parts with 5 gals before it gets used up.
Grand Island, NY
Hello,
I had a great experience with a gallon jug of the 6x vinegar at Home Depot, for $20.
The stuff is a great rust stripper, but please please wear gloves.
