Does motor sit level in engine bay?
Avalanche
Massachusetts
The motor sits lower on the passenger side than the driver side. Is that normal or should it be level?
440.
Should be pretty level side to side. Front to rear is pretty level too. I didn't check the tire pressures before measuring, but they look about the same.
I agree , the engine always slopes down at the rear but should be even side to side .
440.
How does the motor mount look?
I had this happen before with the rubber mount was split making it lower on one side.
Check your mounts for their condition. If they are okay, you can usually just loosen them and straighten the engine from side to side. The engine will usually sit tail down just a bit. Look at your fan blades in relation to the radiator for an example. They should be in parallel.
Just an update. Motor mounts were good, the air cleaner was bent and made it look tilted.
Here is another stupid question. Does the engine sit directly in the center of engine bay? Side to side. Would the center of carb be directly over center of hood?
The engines are offset toward the passenger side. Extra clearance for the steering gear.
You can easily see this when looking at a Shaker baseplate/adapter ring.
Mine is a tiny bit lower on passenger and a tiny bit lower in the rear. You wouldn't notice if you didn't stand and stare at it for 5 minutes making sure you didn't leave tools on the intake or valley pan or valve covers before starting it for the first time though. :lol:
I just noticed that even though the motor mounts were good, they were different thickness. Causing the tilt, along with a bent air cleaner.
Where is a good place to get good motor mounts?
Shouldn't it be level left to right with the rear up 2 degrees for pinion angle. If you are running the rear end down 2 degrees the drive train will have to be or supposed to be 2 degrees up. I have been told or saw on one of the forums that the factory was 2 degrees up on the end of the trans. I wouldn't think the trans is built with 2 degrees up inside. The crank all the way through the trans should be the same I would think.
Throwing another comment here. If you zoom in on my photo of the level, you'll see it's slightly sloping to the passenger side. That's so when I'm in the car, it's almost perfectly level. Of course passengers change things. There is some rake where the rear of the engine is lower than the front. And obviously the whole engine is shifted to the passenger side for axle alignment and room for the steering gearbox. Ideally the driveshaft should be sloping down from the back of the transmission to the rear axle the two degrees at most. Everything level would be ideal, but it's not likely to happen with the given geometry.
It's not uncommon for an engine to not sit level side to side after install or replacing motor mounts. There is just enough slop in each of the bolt holes that can allow it to lay over on one side a degree or two. Simple fix is to loosen the main bolts and lift the low side up with a jack or hoist, maybe give it a jolt to move a bit. This is often enough to shift things where they are level and then you can cinch down the bolts and everything will be fine.
Other than cosmetic, is there any issue with it being that way? Performance ir wear issues? I can't think of any but I'm no expert.
Performance issues...typically no. Depending on how far its off, it could create extra wear on clutch linkage bushings, or possible binding in automatic linkages. It can also create issues with clearances, especially when using headers and bigger than stock torsion bars. Fan to shroud spacing might also change a bit.
