WTB ‘70 Challenger SE Rear Vinyl Roof Moulding
Morpheus
England
This is the very hard to find moulding that wraps around the rear end of the vinyl roof area. I believe it is wider than the standard moulding - 3/4” as opposed to 7/16”
I have this , new. Bought for a 70 challenger
Ok. Is it an OEM part? as I didn’t think anyone currently made a reproduction of this particular moulding
Howdy If this is the long pieces, two, of trim that covers the edge of the vinyl below the rear window I have them. I bought them for my Cuda' and discovered that they were for a Challenger. Thank you Bob
Howdy. I'm not sure exactly what is needed, rereading it again I'm still confused, I will play the old guy card. When I get home I will upload a picture of what I have.
Hi Bob, I have the thin strips that hold the vinyl in place, but as Moparlee says, I require the outside stainless moulding that goes over them. It is 3/4” wide
Howdy. Here is a picture of what I have, I was wrong three pieces. I laid in my 2015 to show kinda where it lays. Let me know if this what you are looking for.
Hi Bob, that looks like it could be right. Can you take a measurement of the width of the stainless moulding please. It has to be 3/4” wide to be the correct SE trim. Thanks
Howdy I hope that you are having a wonderful weekend. I was out in my shop and I got some measurements it looks like we have a winner. Here they are let me know your thoughts.
Thanks for confirming the width Bob. Can you also just clarify when you say ‘3 pieces’ - do you mean 2 long strips & a small connecting piece? or 3 strips? Also do you have any of the clips/fasteners to attach it with? Thanks
(Photo for reference)
Howdy When I get a moment, I'm going to head over to a buddy's house and check the fitment, as I was searching the web for pictures a concern crept into my head. The picture that you posted looks like what I have, but I want to make sure. As for clips do you have a picture as I wasn't good at labeling bags of clips as my memory was good now not so good.
Ok no problem 👍
Unfortunately I don’t even know what the clips look like, as mine were missing! However, I believe there were 3 on each quarter panel and 6 along the upper part of the dutchman panel, so 12 in total. Maybe one of our knowledgeable FEBO friends can help with a picture of the fasteners??
Ok no problem 👍
You might need two different types of clips. Originals attached on studs but if the dutchman panel has been changed there may be just holes in the dutchman.
Howdy After some thinking time while cutting the grass I think that they were plastic rectangular shape for my Cuda'. After NHRA is over I will head to shop and dig through my clips.
Dutchman panel is rotten and will need replacing, so I will have to lay out new holes for the fasteners. I presume the fastener studs go through holes in the thin stainless strip that is attached to the dutchman first?
