Stripped Sheet Metal Holes
money pit
What is everyone doing with stripped sheet metal holes? The easiest thing is to get a larger screw. But what do you do with the holes for the sil plates or other areas that are visible? I tried JB weld Steelstik, that didn't work. Should I use the liquid epoxy or thread lock? Thanks
1972 AAR Cuda
Washington state
I bought a sheet metal nut insert that worked very well for items like the side mirrors mounted on the doors.
I recently replaced my tired chrome drivers mirror and added a passenger mirror with aftermarket painted mirrors using sheet metal nut inserts;
I know, I hate buying from Amazon, but this things works great!!!
floyd
I’ve seen recommendations to use a piece of solid copper wire fed into to the hole while twisting the screw in place.
I saw an older post on a restoration forum where a guy recommended using some older GM or Ford brass or copper emblem barrel clips. I’ve never been able to find anything other than steel or spring steel barrel clips however, which are too hard.
Seems like a great idea for a auto restoration product. A soft metal press-in insert that would jam into place while inserting the original size screw.
I also did the starter relay. I can be problematic. A smaller nut, bolt and washers can also tighten the hole up.
money pit
Thanks. I'm just the opposite. I buy Amazon since it's free shipping and you know if they have the item.
money pit
If this was wood instead of metal, I could jam a tooth pick in the hole for the screw to bite. I guess a copper wire would do the same. Thanks
Chally
I’ve had success tightly wrapping a small piece of copper wire in the threads of the screw, squeezing the wire ends in with needle nose pliers to ensure the wire is threaded into the hole with the screw. Worked on numerous locations on my Challenger.
money pit
Do you use a strand of wire from a certain gauge of wire (14 gage)? or do you use solid core wire? Thanks
Chally
I use solid copper wire, fairly small gauge to fit close to flush into the screw threads. I believe the wire I’ve used is from telephone line or thermostat line wiring left over from building my house…I found this approach more successful than bending the wire into an “L” shape and placing it into the hole as sometimes the screw pushes it out.
money pit
Great idea. I'll give it a try. Thanks
