6 way adjustable seat track restoration
challboy728
Ponchatoula, LA
The seat tracks in my 1970 Challenger T/A were very stiff. I am having the seats re-upholstered, so I figured it was a good time to restore the seat tracks. I disassembled the 6 way seat track and found one of the zinc guides had a flange broken off. I did a search of the interweb, and did not find anyone that had these available. Does anyone know of a supplier or does anyone have one they would be willing to part with? See pics.
Also, I didn't see anything on the internet with instructions on how to get the 6 way seat track apart. I discovered you have to push out the studs that bolt the seat track to the body. I used a vise to do this. You have to fully support the flanges on the hat section profile of the track to avoid deforming it. I put a nut on the stud, flush with the end, to prevent damage to the threads. The stud will push out of the plate, but will not push all the way out of the hat section profile (the head hits the vise jaw). However, I found if you keep the stud clamped in the vise, you can wiggle it out of the hat section profile. Once the studs out out, the track will come apart. Be careful not to lose the rollers and guides (as shown in pics). Also, I found 1 stud is shorter than the other 3. You will want to be sure to reinstall it in the same position.
I had the same issue on mine.
I made new ones from brass. Probably better than original.
Helps if you have a mill, but can be done with a file with skill and patience.
Great suggestion! I know a couple of guys with machine shops. Thanks, Max Wedge!
NP. 1/4" or so brass stock, mill it as a profile and trim to 1/2" segments. Not too big a job. Radius may need to be hand filed.
One nice thing is if you have to hand fit them, you can get a tighter assembly than the factory, so maybe better than stock.
Hi challboy728,
I’ve just stumbled on your thread here & as I too am restoring a 6 way seat track, just wondered if you knew where I could get a new set of springs? (mine are junk!).
Hi challboy728,
Which ones do you need? the coil springs are similar to standard track seats.
The "hair" springs are tougher - mine were broken. I just used hardware store coil springs and wired them in tension to the cross bars to actuate the locks the way the hair spring does, but you need two coil springs per side.
I am missing one of my horseshoe shaped "hair" springs also. Was thinking about trying to get some spring steel and recreate them since they are pretty basic shape, but not sure past that.
Your idea of coil springs in tension is interesting and fairly simple, will have to look into that.
I have the ‘hair’ or ‘clock’ springs that fit to the connecting bars. I just need all the other coil springs.
I can’t find any Mopar specific springs for sale on their own, without having to buy a complete seat track. I did find a set of 3 springs designed for use on a late 60’s Mustang/Cougar & wondered if I could adapt them. Have you had any experience with these? (yes I know it’s a Ford!!)
I might be able to measure it in a week or so. I have a B body 6 way on hand but I don't know if the springs are the same
NPD
has mopar springs
