oil weight
booyaballer
i'll be changing the oil in my 70 challenger which has a 360 crate engine. The manual says 10-30 is what is recommended which would be if the car was new. being that the engine is from 93, would that change or stick to the same 10-30?
for whatever reason, the last time i put 20-50 in it, though i don't recall why but it definitely had zinc in it.
still learning so i'm open to any advice.
Thanks.
Valvoline VR-1 Racing is probably the best and most cost effective oil for flat tappet engines. It's ALL I have used it in my wedges and Hemis for many years.
The best test for choosing the right viscosity is to take readings with the oil you have in the engine now at operating temperature. 15 pounds at hot idle and about 60 pounds max is all you need. And your old oil will probably read a little lower than fresh oil will. I run straight 30 VR-1 racing in my Hemi just like I have in my big inch wedges. Never a problem. But if you like a multi better than a straight weight, then use that. I have an Accusump to pre-lube the engine before I hit the key, so multi grade oil does not have any advantage for me.
SJ Or at worst SL is the only oil to use , ZDDP is more important than the weight , Agricultural oils from farm supply are all SJ as they are off road use .
the engine clearances are generally created for a given oil , more clearance for heavier oils & tight for lighter oils , I typically used 10/40w before all of the oils had the Zddp removed
Yes, get oil with zinc and phosphate. I too like to run straight 30 weight, but really having the zddp is most important! Even if you have to buy an additive and mix it in.
Thanks.
Liqui Moly makes a 10W-40 that has zinc and MoS2 (Moly) in it. This is an oil for your muscle cars engines with hydraulic flat tappet cams. The Moly creates a robust load bearing oil film for extra protection and reduced friction.
Thanks.
Thanks.
Castro GTX Classic is a high zinc oil designed for muscle car motors. Check it out
Available at NAPA or online, p/n 2042.
Is liqui moly have zinc in it? Or is a substitute for zinc?
This oil is for older engine designs (with flat tappets). It has zinc and Moly which provides a robust load bearing oil film for added wear protection for all the internal engine parts, especially the cam and lifters. One liter bottle p/n 2042, five liter bottle p/n 2043
