340 Heads intake valves
Don't have valve seat inserts fitted to the intakes if you do you won't be able to fit them to the exhaust which you should do. Have them crack tested before you spend any money on them.
Is it necessary to run 273 rockers with the bushings? I have 15 without, and only 1 with a bushing.
Thanks. They were all nice and smooth inside, except for one. Would it hurt to try and sand this out, or should I toss it and look for a new one?
If you can't find a replacement you could have a bush fitted like the other one. What does the shaft that this rocker was running on look like?
Not sure. The seller had these in a box mixed in with non-automotive parts. The shafts were not to be found. He said he moved several times over the years and a lot of parts seemed to have disappeared.
