Matt L.
- Joined
- Jul 23, 2020
- Messages
- 79
- Reaction score
- 24
Is there any way to tell the date the alternator was made?
Thank you....again!Assembly date code is on the pad shown in your third pic. That one looks to have been rebuilt/remanufactured and most of the debate stamps were probably lost during media blasting of the case.
Do you know anything about the pink markings from the factory inspection? If you zoom in on the right hand side you can also see a little yellow to the left of the pink.Assembly date code is on the pad shown in your third pic. That one looks to have been rebuilt/remanufactured and most of the date stamps were probably lost during media blasting of the case.
TYVM for your thorough response. It does have the single groove pulley and appropriate part number for that. The car was restored in the early 90's and I think they actually tried to keep everything together. Do you think this would be the original alternator off of my 71 cuda w the 340 engine?As Floyd notes, this alternator looks to have gone through a mass rebuilder process and was blasted, or more likely tumbled with metal shot which damages the markings. The stamped part number appears to be 3438178.
Alternator number 3438178, as stamped on the identification pad, is a production alternator rated at 50 amps, and equipped with a double groove drive pulley. The service replacement part number for 3438178 is the same number, 3438178. In some cases, the service part number differs from the production part number.
The stamped date code is illegible in the picture. Rubbing graphite over the area may make the numbers more readable. It's possibly sometime in 1970.
This alternator used the rectifier (rear) end shield part number 3438204, casting number 3438201. Yours is the casting number, but the casting date marking is worn down. This shield was only made in 1969 - 1971 for 1970-1971 production though.
The drive (front) end shield is part number, 2095945, casting number 2095191. Yours is the casting number, but the casting date code marking is not in the picture. This shield was made in 1963 - 1972, but use varied some.
Alternator number 3438178 was available in all car lines, depending on accessories, etc. in 1970 and 1971.
Also, is there any way to tell what day the engine was assembled?
