gman72
Ok I am a new member with zero experience on Barracudas. So forgive me if my questions are basic or just plain dumb. Although my wife would tell you dumb questions from me are somewhat expected. I have a 1973 Barracuda 340, automatic. I just got it about a week ago. My fuel sender has 2 ports. The fuel delivery port going to the pump, and what looks to be a return line. The return line is not connected to anything. Imagine my surprise the first time I tried to pump it full of gas and my fuel return line started to relieve itself all over the ground at the gas station. Fire departments and hazmat units were called and were crawling all over the place.
I also have a vapor liquid separator. The 4 lines that are supposed to go to the tank have nowhere to connect. The tank is lacking the ports. The 5th line from the vapor liquid separator is run to the front of the car and is not connected to anything.
I have attached pics of this. I know we touched upon this on my welcome wagon thread, but I figured I would ask more questions on a new thread. Also I am not looking for this to be a concourse car. I just want a safe car to drive and enjoy. Some spirited driving may be occur as well. Now for some questions.
1) Where does the return line to the sender connect to? Does it connect to the manifold, or the breather cap with the 3 ports. Or should I just block it off? (I got the car without any hoses connected to the breather cap)
2) Since my tank is not from a 73 and has no ports to hookup the vapor liquid separator, will that be a problem if it is left unconnected? Can I use the line in my engine bay to hook up to the fuel sender port?
3) I am going to replace the rubber fuel line shown in the pic with the alternator I put an arrow pointing to it. Is that line run correctly? The oil dipstick is right up against it and whenever I pull out the dipstick I hit into the fuel line. And can anyone point me in the right direction for the proper fuel filter that comes after the pump?
thanks.
thanks.
