73 barracuda truck extension missing curiosity.
Flathead31coupe
Indianapolis
While installing the rear valance, I realized that There are no trunk extensions installed.. It had new quarters, and trunk floor that was already installed when I got the car.. As I was looking at pictures on the web , I noticed that about three out of every five pictures do not have trunks , extensions as well thoughts?
So I have decided to put trunk extensions on my project. I have a question.\n I saw a couple of videos where the trunk extension and the quarter panel at the bottom were not welded solid together. Does anybody have a thought on how they are done or supposed to be connected to each other?The curved part of the quarter panel at the bottom and the lower trunk extension bottom piece.Thanks
if I'm understanding your question correctly, this is the area behind the rear wheels. an area that is often rusted, particularly in snowy areas with salted roads. but even in dry areas, like southern california, the lower quarter area behind the rear tires is prone to damage and rust.
the trunk extension (inner quarter panel behind the rear tires) and the outer quarter panel are spot-welded together. they form a cavity. A nice place for small tools, housekeys, loose change, credit cards, and other small objects to collect as they fall from the trunk floor down into this abyss at either end of the trunk floor. Not to mention, dust, dirt and other debris collect in these areas, over time.
sadly, the areas around the back window and where the quarter panel meets the dutchman (trunk filler) panel and forming a lip for the desk lid, are prone to leakage. when it rains, where does the water go? onto the floor of the trunk, and then down into the aforementioned abyss.
combine this with the dirt and debris collected in these areas, and you get a wet soggy area that doesn't drain well, and in time, can rust through and show.
the trunk extension area is labor-some to repair, and I'm not surprised by your finding someone, somewhere along the way, decided to take a shortcut an minimize that pocket of rust-producing sludge on your car.
if you want to put it back, and make it correct, that's your right. from memory, this area is practically water-tight. I have cleaned these areas on prior cars. the two panels are spotwelded together, so well, one can fill the abyss with water from a garden hose and watch is slowly drip, drip, drip onto the ground. There is a removeable plug, about the diameter of a silver dollar, on the inner trunk extension, to help it drain and clean it out. but leaving it out seems a bad idea, because driving through any kind of water, be it a puddle or a rainstorm, seems to throw water from the rear wheels right onto that area.
that said, it seems wise to facilitate drainage from this area, so a weaker seal along the bottom edge of the abyss would be of great help. But again, it's unclear if water spraying off the rear wheels is a factor, if that area is left open. open to drain, and maybe open to fill from the rear wheels? It could be argued it is better to leave the area sealed and resolve the water issue from above.
this whole area is almost a design flaw of problems. most modern cars resolve this with a plastic inner fender well to divert water from washing onto the area. And most modern cars don't form this type of abyss or cavity going from the passenger area, minivan floor, or trunk all the way to the bottom of the quarter panel.
Following along.
I have this issue on my right quarter on my ‘71 vert. When it was flange repaired with a graft from a ‘72 quarter around 1990-2 it happened.
No reproduction panels back then.
I’ve been debating what to do as well. The flange seam is visible inside the trunk.
the trunk extension (inner quarter panel behind the rear tires) and the outer quarter panel are spot-welded together. they form a cavity. I nice place for small tools, housekeys, loose change, credit cards, and other small objects to collect as they fall from the trunk floor down into this abyss at either end of the trunk floor. Not to mention, dust, dirt and other debris collect in these areas, over time.
if you want to put it back, and make it correct, that's your right. from memory, this area is practically water-tight. I have cleaned these areas on prior cars. the two panels are spotwelded together, so well, one can fill the abyss with water from a garden hose and watch is slowly drip, drip, drip onto the ground. There is a removeable plug, about the diameter of a silver dollar, on the inner trunk extension, to help it drain and clean it out. but leaving it off seems a bad idea, because driving through any kind of water, be it a puddle or a rainstorm, seems to throw water from the rear wheels right onto that area.
that said, if seems wise to facilitate drainage from this area, so a weaker seal along the bottom edge of the abyss would be of great help. But again, it's unclear if water spraying off the rear wheels is a factor, if that area is left open. open to drain, and maybe open to fill from the rear wheels? It could be argued it is better to leave the area sealed and resolve the water issue from above.
As I mentioned earlier about 3 out of 5 cars , I looked at do not have the trunk extensions and our finish and painted.. I was just curious of how they were put together where the two meet at the bottom of the quarter panel
Just trying to figure out the best way to install these.. Any suggestions on should dos , or must dos.. Or would do if I was you l o l...
Thank You..good read.
I'll admit to not looking under E bodies regularly, but I have never seen one without these extensions.
In any case, if you want to add them, it shouldn't be too difficult. Put them in place, spot weld, touch up the paint.
However, if you never noticed they were missing before, then someone must have filled the gap in the trunk floor to prevent things from falling out on to the road. This makes your work more difficult as you now have to remove these pieces before you can add the correct pieces. If you didn't put these pieces in place, then its anyone's guess how well or poorly the previous owner actually closed this gap and how difficult it will be to remove and correct.
Ok thanks
Does anyone have any pictures of these being installed...
If I remember correctly, they were plug welded to the trunk floor, outer wheelhouse, tail panel and quarters. Where the qtr extension meets the bottom of the quarter panel was plug welded too. Seam sealer is used in the trunk to seal the panels abutting the extensions.
For some reason , it will not let me upload anymore photos.I will keep working on it
If you have the picture open in your own folders on your computer you can drag the picture to the body of the messaging here. Instead of "uploading photos".
I am unsure of how to upload from a phone.
Cool looking project, I was talking about your lack of drop pictures though.
But I love seeing the actual project. Do you have a thread on your car yet?
