LOST INTERIOR POWER
Lee W.
Newcastle Ca.
1972 cuda Had to jump start the car it started ran for about 15 minutes turned it off. went to auto parts got new battery hooked it up now I lost power to the whole interior. ignition switch, head lights, turn signal, dash lights. not the battery can jump across the solenoid engine turns over wont start. Thanks for any help you can give
make sure to grab your PDF of the service manual, for your reference. The wiring diagram will show the majority of interior power is fed from the battery POS terminal, through the fusible link (these can blow) and on to the bulkhead connector, where it is picked up by the fuse box and interior wiring distribution.
Since the battery was recently fiddled with, I'd start at the battery POS terminal, and follow the flow back through to the fuse box and ignition key.
Did you change anything other that the battery? Perhaps the battery cables? Is the GROUND to engine and chassis still good? You may have something simple like a loose connection near the battery on the fender well.
Clean the battery terminals so the shine like a new nickel. Fuse able link start there. move it around see if things come on. Then the bulk head connector. then the plug under the steering column. Check battery grounds.
Ill try to check fusible link tomorrow. the battery is not the probably it is located in the trunk and I have power to the engine compartment. I do have a pdf manual will try to follow it. Thanks for getting back to me
Not the battery. battery is located in trunk and i have power to the engine compartment. hoping not bulk head connector. Don't how to repair that. thanks for getting back to me.
Probably blew the fusible link.
Low battery voltage will result in higher current draw across the link.
I am hoping you are right. but it is probably too easy! nothing has been easy on this car. will try to check it out tomorrow and let you know. thanks for getting back to me.
ahh, battery in the trunk, that is VERY good to know. the number of things to check has gone up. In many cases, when owners are having power problems, and the battery is in the trunk, the cabling can indeed be the issue.
a good friend talked me out of relocating my battery to the trunk. he taught me moving it to the trunk can increase overall weight, because the cabling running from rear to front. Still, it's a common change for some.
if the battery is far from the fusible link (normally located on the driver side fender well of the engine compartment) I would first confirm the battery connections from the trunk to the chassis and starter motor (and others) is full functioning. The fusible link can indeed blow, but I've never had one blow in many cars, many years. Simply checking continuity with a DMM will tell you if it's happy.
I am still working on it when I can. I have already removed a mile of elec. tape and still no fusible link
