Ididit Steering Column Wiring help needed
SFEbody
Los Angeles CA.
I am a simple mind I guess, but just for the worls of me cannot figure out the ingnition wiring for the IDIDIT tilt column. If anyone has used hte ignition relay please let me know how to wire it up in simple terms. The turn signals are straight forward, but the ignition side has me pulling my hair out.
Thanks in advance
Brian
Not knowing anything about IDIDIT tilt columns, I'd give them a call and talk to them about my problems. I've discovered over the years most suppliers are very helpful and actually love talking to and helping costumers. They like to chat just like the rest of us!
I didit uses GM switch , , relays are simple 86/87 are low current power in & ground out , 30 / 85 are the high load power in & out to the start solinoid
I have the same problem. Can't find an adaptor for the module they sent for my under dash and they say my model requires an adaptor they no longer have. I'd like the use the under dash plug.
Forgot to ask how you solved the problem. Their module uses slots and the harness needs a female plug to work. Are there other places to put the wires with the slots?
