Automatic Console Hump
zslacker
Castaic Ca 91384
The previous owner of my 1970 Barracuda hacked out the center console, leaving nothing but a unfinished project. I am putting an automatic back in and need the metal hump however I can only find a 4 speed hump or the entire AMD floor pan which does not come with the brackets for the console. Is there any place I can get proper parts with the brackets, new or used? I did find a 1973 Charger with an automatic console thats getting parted out, will that will work?
That would be correct. All factory floor pans are automatic. If it to be a 4sd the floor is cut and the 4sp tunnel is put on. I want to say the 71 charger is the same. Not sure about 72 and up. I'm thinking they are. If it looks like it it just might be. Pull a few measurements and check it. If it's cheap enough just get and make it work. You probably would save a lot of time. Of course don't forget the obvious, Barracuda and challenger the front is the same. Someone here might have one. or know it it will fit. Post it in WTB.
Wow, I was unaware the base hump and floor pan were different on manual vs auto.
AMD, Classic Industries, Summit Racing, and JEGS all sell a full floor pan with hump, but make no distinction between manual vs auto.
Front Floor Pan - OE Style - 70 Dodge Plymouth E-Body
I do believe they sell the center console bracket sheet metal, separately, so I know that one can be had reproduction.
Unless you're doing the work, yourself, it is common that making an existing sheet metal work costs more labor than installing a new AMD repop. Not always, but pretty often. When a repop saves 2 or more hours of labor shop time, it usually pays for itself.
The floor pans are different, but I'm pretty certain the transmission tunnel is the same or close enough between the 70 Cuda and 73 Charger. It will be covered by carpet.
And yes, more work was done to add the four speed "hump" from the factory. I believe that's why the 69(?) Roadrunner switch to the automatic standard and 4 spd optional to keep the base price down. Look at production numbers and you'll see a lot more automatics were made than 4 spd (and 3 spd) cars. Very few models have more 4 speeds than automatics. Which is why I think Chrysler was trying to keep costs down. Remember, Chrysler has the Kokomo aluminum plant which is still one of the biggest (if not biggest) aluminum plant in the world.
