14x6 Wheel Information Confirmation
Desert 70 Cuda
CA
Hello,
I'd appreciate if someone can check my work. Recently purchased a 14x6 wheel and based on the stampings I've concluded it's a May 15th, 1975 wheel with part# 3580060.
The part number 3580060, based on what I've found is a 1972-74 for "B" body wheel. It was manufactured in 1975, correct? Or is the year range the lifespan of the part number only? Or is the year range of the part number when it was manufactured and the date stamped right before it was installed on the vehicle? I'm confused by the "M35_5_15", the 5 after the M3 is supposed to represent the year which is outside of the year range of the part number.
Thanks, just looking to better understand.
Your data looks accurate, to me.
A physical part and its specific part number (for any part, not just wheels) may have been shipped from the factory on only certain models, and certain years. But these parts were available from the parts counter at the dealership, too, even years after the model year of the car.
if your M35 indeed refers to 1975, then is seems possible this very wheel was not shipped on a 1972-74 B-body from the factory, but instead ordered through the parts counter a year or so later.
Another example, the date codes on Carter carburetors can be newer than the cars they came on, because owners could still order new parts years after the given model year ended.
Thank you Pschlosser, that's helpful. Some times part numbers vs dates can get a little murky.
Hi Larry4406, I'm not completely sure, I grabbed from a FB post but I believe its a wheel parts catalog of sort. Here is the whole pic i downloaded.
The pictured wheel listing is from the Galen Govier "White Book", called "Chrysler Corporation Part & Casting Numbers Book".
The following image shows the cover of the book:
The following image shows the Wheels page from the Sixth Printing version of the book (page 45), which covers 1970-1974:
It looks like you got the initial post wheel identity confirmation okay, and with the date of the pictured wheel, it is probably a service replacement wheel.
FYI:
Following is a general listing of Chrysler 14" x 6" wheels from 1957 - 1989:
14" x 6" Steel Wheel, 5 x 4.5” bolt pattern
Part Number
(latest number superseding earlier numbers)
Application YearsGeneral ApplicationsNotes
20843711957 - 1958
  • Full size, Chrysler, Desoto, Dodge, Plymouth.
Includes 1736689, 1850887, 1881980 & 2122433.
22758981959 - 1963
  • Full size and intermediate, Chrysler, Desoto, Dodge, Plymouth.
Including B-body and C-body when the designations started.
24483771964 - 1965
  • C-body
25347061966 - 1968
  • C-body
29443271970
  • B-body
34209781970 - 1974
  • 1970 - 1971 E-body,
  • 1970 - 1971 B-body
  • 1975 B-body
34619541972
  • B-body
35800601972 - 1974,
1988 - 1989
  • 1972 - 1974 B-body
  • 1988 - 1989 M-body
3621954
  • 1976 B-body
  • 1976 - 1979 F-body
41266031976 - 1980
  • F-body
42843031987 - 1989
  • Dakota
Deeper offset.
NOTE: I'm still working on this table, so there might be some adjustments yet to do.
This is amazing, thank you so much Vaanth! So cool that you're sharing this and consolidating all in a table. Thanks again!
