Riser block rear suspension???
440 Smokin
74 Cuda with a 440 and Tremec 5 speed. The car rides like a log wagon, especially the rear. Almost no give when you try to bounce the rear of the car. It has 6 leaf springs and for some reason an 1 3/4" riser block between the leaf springs and the axle bracket. KYB 554285 shocks. Not sure what the purpose of the riser is. Stiffen the suspension? Lower the stance? Rumor is it used to be a drag car, there are a couple of Mopar National window stickers on the front window.
So I want the car to ride better, more give in rear end. Willing to replace the springs and shocks. Maybe a premium adjustable shock like a QA1. Remove the risers? I like the stance of the car but would really like to get a decent ride and not have to inch over speed bumps anymore.
Any thoughts?
Thanks........
those blocks lower the rear of the car . i would unbolt the shock and measure the distance between the upper and lower shock mounts we will call the ride height .. then measure the shock fully compressed and fully extended the ride height should be between the 2 measurements of the shock .. if the ride height is to close to either the compressed or extended measurement of the shock the shock is bottoming out and it will ride like it has square wheels
Removing the block will not change the ride at all .
You may have SS springs if it is sitting too high without the blocks ,
I would try better shocks first , double adjustable work best .
If it still is not what you want you can order different springs , the rear of the spring controls the ride , the front controls traction so you want as many as possible in front using 1/2 leafs .
Kinda sounds like you have SS springs. Get rid of the blocks! They probably ran a tall tire 29" or 30" diameter slick and wanted to lower the rear and added the blocks. Might be better off with these, the extra heavy duty 426/440 springs: P4452984 right and P4452985 left. They use 1/2 springs in the front. Unfortunately the right one is on backorder. Looks like maybe the end of July they might be back available.
Definitely go with the QA1 (or Bilstein) shocks! KYBs were cool when they first came out because they were better than factory or factory replacements, but there's better shocks available now.
When the axle is under the springs, that is a riser block because it will lift the vehicle. When the axle is over the springs, as in our cars, it is a lowering block. This black has nothing to do with ride quality unless it lowers the car so far the axle tubes are hitting the bump stops. At 1.75", I sincerely doubt that is the problem. If you remove them, the rear will be 1.75" higher. If you raise the front end 1.25" to 1.5", the whole car will sit higher with a slight rake, eliminating the need to go slow over bumps. So this may be an option to consider, but it has nothing to do with ride quality.
I'm also of the opinion that a 6 leaf spring pack is the equivalent of the factory HD suspension and should not be overly stiff and you should be able to push the rear down some amount, unless you only weigh 110#. Heck 318 and 225 cars had four leaf packs, so your only up a couple leaves from the lightest weight option. I doubt the leaf count is a problem because in your picture, I only see 4 full leaves. I'll assume the extra two are half leaves. You car should ride pretty decent.
KYB shocks are high pressure, divergent valved shock that create a very high initial resistance that will slowly give way with increased load. More load than you can get by just pushing on the car with. In any case, this high initial resistance is where small bumps and road cracks move the shock, the KYB will be putting up its highest resistance and creating a potentially rough ride. It's only when rapidly throwing it into corners that the KYBs work well because they slow the suspension reaction down significantly on the initial compression.
I'd recommend removing the shocks and then pushing on it to see if that allows the motion to free up. If yes, then the shocks are the problem. Is it the shock valving or the shock travel...that depends. With the car on the ground, and a large bar clamp, you can try compressing the shock to see if it allows enough travel to match the suspension. Even with lowering blocks, there should be adequate travel between the springs and shocks, but you never know until you check. If you had high arch springs, like Super Stock, then it could be possible you are running out of shock travel.
Out of curiosity, are there any additional clamps on the springs anywhere along their length? If this is indeed a former race car, they may have added extra clamps to help with launch.
Thanks for all the replies. Found out that it has "drag springs" that are two inches shorter as well as front hanger brackets that are 2" longer. Ordered new stock springs from General Spring as well as QA1 single action shocks.
Nope, no additional clamps. Springs are 2" shorter than stock springs. Replacing them with stock springs from General Spring and QA1 shocks. Thanks for the detailed reply.
Upon further inspection determined the leafs are 2" shorter than stock. Ordered new stock style (for 440) springs from General Spring and new single action QA1 shocks. New shackles and front hanger brackets. Hopefully this will return to a stock ride. Thanks for the replies.
When I was in school ag class I made some longer shackles for my 67 GTX and put them on many years ago and still have the car
Glad to hear you have a plan of attack. The QA1 shock will certainly help with improving ride quality.
Interesting to hear that you have SS springs. It appears these have been modified as the picture posted did not look like them. The 2" shorter segment is a dead give-away that's what they are, but usually they have 2-4 more leafs in the packs than what your picture showed.
So over the last week I have replaced the shackles, front hanger brackets, springs, shocks and sway bar end links. I removed the lowering blocks. Springs were from General Spring. I didn't measure the rear end height prior to but it is significantly lower than before. Maybe 4"?? So parts wise it is as close to stock as I could make it. What I have found after doing all this work is the fender well lip height to the floor is all over the map.
Pass front- 28 3/4
Driver front- 27 3/4
Pass rear- 25 1/2
Driver rear- 24 1/4
The hangers I replaced were 2" longer to accommodate the drag springs that were replaced. After I noticed the back end listing to one side I inspected the old hangers and found that one hanger the springs were bolted in the upper hole and the other hanger the lower hole. At that point I didn't know which hanger came from which side. Measuring the torsion bar adjustment bolts with a tape measure it seems they are about the same length in the housing. Granted that is a rather inaccurate measurement.
One could assume this side to side condition is pre-existing and the previous owner corrected it by using the upper and lower hanger bolt location. But that is just an assumption.
The rear suspension is now as stock as I can make it parts wise. Haven't done anything up front yet. What could be causing this out of level condition?
I understand I could change one of the spring bolt locations in the hanger to return to the upper/lower holes and this would likely make the rear difference side to side tolerable. I also understand I can lower the front end by adjusting the torsion bar. But can I use torsion bar adjustment to correct the front end side to side difference? Likely the two torsion bar tensions would not then be equal but will that cause any harm? Can torsion bars loose their resistance unequally over time?
So lots of questions and a possible solution that I don't know is viable.
Thanks in advance for any assistance.
I believe if you adjust the front with the torsion bars so they are equal on driver and passenger side, it will level out the rear. So if you drop the pass front an inch, it should raise the driver back. Will you get the full inch? Maybe, depending on how the back leafs are done.
one more thing about adjusting the torsion bars . jack up the front to get the weight off of the suspension before adjusting them if you don;t you could strip out the threads
Set the front end height the same, then check your rear height side to side. Once you get your ride height sorted out, you're going to need the front end aligned.
Yes, jack the front end up to take weight off of the suspension. You might need to spray some wd40 on the nut to get it to move.
The SS springs you took off have a bias built in to them to allow the car to launch straight at the drag strip. This bias tend to make the drivers side of the car sit higher. Mismatching the bolt holes for the spring mounting is one way to compensate for this appearance. Adjusting the opposite torsion bar another way to do this. The previous owner likely did both.
Since you replaced the racing bias spring with stock springs and equalized the mounting, now your t-bar adjustment is off. The length of the t-bar adjustment bolt is not always equal. These can be off by quite a few threads.
To re-level the car, I would only adjust the driver side bar up. It is an inch lower than the passenger side. Additionally, by raising that front corner, it will also drop the passenger rear corner. This is because the weight transfers diagonally across the car and does not transfer front to rear. This is the “wedge” that is often referred to by some race drivers.
Like others have said, raise the car to unload the control arm, screw it in a turn or two, drop, bounce, re-measure. These are a fine thread screw so a little turn returns very little movement. The bouncing is important to the process to reset all the bushing positions after lifting.
I would also check your driveshaft angles once you get the suspension heights sorted out. The Tremec 5-Speed requires correct angles to prevent damage to the output shaft bearing. Rear suspension changes can wreak havoc on driveshaft harmonics when the driveshaft angles do not cancel out. Check them to avoid a costly future problem.
You actually have that backwards, the SS springs make the passenger side sit higher. This is covered in the old Direct Connection suspension manual and I also have them on my car and can attest to that fact!
Yes, SS springs were used for roundy rounders too! And you want a little more weight on the inside. Regardless, everyone is spot on about making the front ride height the same by adjusting the torsion bars. That will definitely help out the rear.
You're right. In my fat finger typing mode, I got em backwards.
