73 barracuda quarter glass adjustment question.
Flathead31coupe
Indianapolis
When adjusting the quarter glass.. Should the quarter glass be adjusted to meet right in the center of the drip rail channel when rooled all the way up ?. I am attempting to make adjustments before I put the rubber in the drip rail channel... I guess what I am asking if you didn't have the rubber weather stripping in where would the window be right , left or in the center of the channel.
Do you have the body factory service manual? For a 73 Barracuda, go to chapter 6 page 27 and the instructions for your door and quarter glass adjustments are there. Follow those and you should be good to go.
Unfortunately, I do not.I know how to adjust the glass in and out and up-and-down.I just don't know the position of the glass.Is it closer to the inside edge to meet the rubber or is it right in the middle... From looking at it , it looks like it needs to favor the inside of the car more to get it to seal correctly
I'm also trying to find information on installing the weather stripping, it looks pretty self-explanatory.It goes in the groove at the top of the drip rails.. But after the bottom, it looks like you can unfold it and wrap it around the molding on the inside, not sure.If that's the way it goes or not
I have a few pictures.Does anyone know which one of these is the proper way to install this weather seal...
