Needing fender tag information (questions)
gran coupe john
Ohio
Have the original sticker price for my car. My question is what the original fender tag would look like with the options this car has. Picture below. I tried to get Diane to do one, but I hit a đź§± wall.
From what I have seen theJ55 and t22 won't be on the fender tag. Not sure when Y codes were not used.C16 69-71 Console w/Woodgrain Panel C26 70-71 Consolette w/Formed Headlining G33 remote left chrome J25 69-71 3 Speed Wipers. L 25 trunk light Depends on build date from what I seen. Moparguy more the likely knows.
When you have the window sticker 90% of the codes are on there. You have to be able to read between the lines. But not everything is not on the window sticker.
One has to when the codes are and not applied. The other 10% might figured out with the pats on the car. There is information that is lost without the build sheet.
Without supporting documentation, such as a build sheet and prior fender tag, some of the data you'll just have to guess and fabricate.
I'm not a strong supporter of public discussions teaching others the ins and outs and conjecturing their own fender tags.
But privately, as you put the puzzle together and design out the content of the fender tag, I would support you, when you have questions.
I encourage others wanting to help to do the same. Let's do what we can to minimize would-be abusers of this information.
I recommend some of the finer details be sent via private message.
The car obtains the build sheet, and all the right documents. Just missing fender tag. Want to make sure the tag is correct? What you guys are saying. Not possible?
If you have the build sheet you're golden. There's on more thing on the window sticker that is missing on yous. I'll DM you where to find it.
Sure, its possible to fabricate one. The build sheet has all the data you need for an accurate fender tag. Even without help from this forum, comparing with other fender tags, it becomes clear which codes are on the tag, and which ones are not.
Yes, there is a passenger side door sticker. I haven't found anyone yet to make a fender tag. Have a couple people I have contacted, but it seems to be a bust.
"there is a passenger side door sticker. "
The only thing I think that would have happened. It was Friday. On his way out the passenger door was on his way out. He wasn't going all the way back to the other side to put the sticker on.
I never seen workers move as fast as quitting time!
