Wanted Clutch /Brake Pedal Assembly
It`s an automatic non-matching numbers car that I`m converting to a 5 speed. Is the Brewers system complete and how is the quality? It seems that when i buy aftermarket parts I always have to modify the compounent to fit correctly.
I never bought a complete package, but the z bar I got from them had no issues.
If you want something original and no one here has it then you can try Tonys parts.
http://www.tonysparts.com/
They may have what you need but are not cheap.
I've got one that came out 73 cuda it' got nuetral switch an clutch rod and the pieces that goes from frame rail to bell housing . Haven' checked out switch if good or not.Just took out of car this week
The 70 set will bolt in any year of car but it is different. The main difference is the pedal shape.
Is the 73 the same as the one they use for the 70 and 71 Barracudas? If so i'm intersted.
Not sure - can tell you it came from a 73 cuda small block I am using as a donor car to build a 73 cuda. I do not need so I am interested in selling
