03HDFB.....Finally Got Around to Swapping to Electric Fan!
03HDFB
So,
Still hunting my ignition gremlin....I think I have it fixed but time will tell! I finally found a few hours to work the
Electric Fan Swap....I have a BeCool Rad with Core measuremnts of 18" x 22". I used the Flex-188 or Black Magic
extreme Series fan from Sumitt.... Perfect fit... 2450 RPM and 3300 CFM. I had already done the wiring last winter...
Sensor activated at 180 deg and run down to 160 Deg. I made (2) quick brackets out of graphite, a doubler plate
so I could make the brackets removable and (4) Spacers. Here's some pics....I still need to swap the bolts for some
stainless button heads....but you know Tacoma screw....never open on the weekends!
03HDFB
Nice. Where would a guy find such cool materials?:eusa_whistle:
I bought a sheet of it years back....while modd'ing my '08.....Bought it from Carbon By Design.
there are quite a few carbon shops....you can ping for some flat materials.
Nice man, love your whole engine bay, just looks clean
Thanks.....I'm getting very close to as clean as I can get it. I hope to add some more ponies soon!
03HDFB
You're detailing that thing very nicely. Gotta love that attention on a car.
Thanks Mike.....And you......You have some Sweeeeeeeet Rides! Can't wait to see the Cuda rolling!
mmissile
Macomb County Michigan
I used to work in a higher-end fiberglass shop, back in the day.[did all the Penske bodies] I never got a chance to work with carbon or the other laminates. Is it a ***** to cut and sand? We did the first carbon police helmets, but they were there for final finish.
03HDFB
Naw......I would rather work in Carbon than fiberglass. Easy to cut and sand. If you have a good weave up front...all you need to do is spray some clear coat
and you're done!
