BoomerSoonerVA
- Joined
- May 18, 2014
- Messages
- 97
- Reaction score
- 0
Okay rebuilding the engine. I cannot get the crankshaft bolt out. Used heat, 1400 ft lbs impact drill and soaked it over night with pb blast. Any other ideas?
If the bolt is not yet broken I would keep trying to loosen it with normal tools then if the bolt head becomes rounded or the bolt snaps get it drilled out as a last resort. What I normal do is put a long breaker bar on it while the engine is still in the car, turn the bar until it jams against the frame or the ground then disconnect the coil wire and briefly turn the motor over with the key this method never fails.
So the balancer and timing cover are still attached?
