How will you make the door trim panels?
Here are a few "rough" pictures of the Interior Door Panels that were custom fabricated to fit the rest of the custom alterations. We used a very hard wood along the Door openings to provide a consistent Window Gap. The altering of the Body Panels caused the openings to be unorthodox so thin wood strips were used to bring the gaps back to a default (straight) opening. The panels will be thinly padded and covered with a grained Vinyl that will match the rest of the Interior. Once covered, the metal sub-panels and wood strips will look like a one piece unit.
You will also notice the black line on the bare Door Panels that is tapered & shaped like a forward motion "V". (Those templates will be replaced once all the fabrication is complete.) That pattern will be recessed and stitched in the Door Panel design and will run back to the custom Foam pieces that are located next to the rear seats.
Also shown is the location of the Interior Light Box next to the rear Seat. When the Carpet is installed, the Box will raise up just enough to perfectly join with the the Rocker Panel (interior) curve next to the Sill Plate.
