Grady Cain
Some semi-final assembly photos of the rear after being detailed. I made stencils for the numbers and letters from a page out of the DW book which referenced the proper font and size for the stampings.
The orientation of my "E" doesn't match the original which I realized after I painted it but, oh well....
I carefully cleaned all of the black paint off the original axle bumpers and repainted the mounting tabs the correct yellow...
Found a correct pinion snubber and brought it back to life...
Original drums still had enough meat on them to turn. Then blasted, painted and cleared...
Backing plates restored. Rear sway bar restored. Bushings are NOT available so I had to mask them and bead blast around them. As much as it will kill me, a final dusting of undercoating will be applied as that would have been done (in this car's case) at the dealership and some of these nicely painted parts and restored original hardware will get partially covered with it...
