Jerry Ikemire
- Joined
- Jun 24, 2019
- Messages
- 34
- Reaction score
- 11
Just a quick one here...were the 318s using non-oiling pushrods back in the day?
Yes, that's why it's imperative that the shaft be installed properly. They *can* be installed wrong. I bought a 440 from a guy once and when I tore it down the shafts were installed wrong! Engine had squealing noise. Shafts & rockers were horribly galled.Toolmanmike is correct! the oil is supplier by holes in the number 4 camshaft bearing that feeds oil into the 2nd or 4th rockerarm bolt pedestal (depending on passenger or driver side head) into the hollow rockerarm shaft.
Not until the Magnum. If the engine came with rocker shafts, they oiled through the deck and heads and not the pushrods.The later roller cam LA engines oiled through the cam bearing and the lifters. They changed the rocker arms slightly. 1989 LA 360 for example.
Respectfully, that is incorrect. I built just such an engine. Look up the part numbers. These LAs oiled both ways from the factory. 1989 360 LA, original untouched engine out of a W250 pickup.Not until the Magnum. If the engine came with rocker shafts, they oiled through the deck and heads and not the pushrods.
I asked around about the rocker shaft orientation and was told the oiling holes go "down and out".Yes, that's why it's imperative that the shaft be installed properly. They *can* be installed wrong. I bought a 440 from a guy once and when I tore it down the shafts were installed wrong! Engine had squealing noise. Shafts & rockers were horribly galled.
"That combo is “partially” pushrod oiled.Respectfully, that is incorrect. I built just such an engine. Look up the part numbers. These LAs oiled both ways from the factory. 1989 360 LA, original untouched engine out of a W250 pickup.
That is correct. The follow up question is, why did Chrysler do that?"That combo is “partially” pushrod oiled.
The rockers have no oil holes in the pushrod cup, so the oil coming up the pushrod only lubes the pushrod & rocker interface.
The rest of the lube requirements for the head are still handled the traditional way." From an engine builder on another site. One fellow says one thing and another fellow says something else.
