34 year quest finally begins.
Ohiowoodchuck
:thumbsup::thumbsup:
Congrats on getting your old man's car back! That's gotta feel awesome. Good luck with the project. Looking forward to the updates. Assuming you'll go back to the original color and stripe scheme??? That was a good looking car back in the day.
Here is a little sample. Since all the old timers have either retired or past on there is no one who can just look up and mix a paint formula anymore around here. They have to use a camera. Luckily I have a part from my first car that is the correct fe5 red. We copied that again and ordered a gallon. Here is a test run to verify. It will give you guys a hint on where the car is going.
Kid power is something else. Even stronger with memories of hearing it going up the street.
Get your motor runnin'
Head out on the highway
Lookin' for adventure
Like a true nature's child
We were born, born to be wild
Cuda Hunter
high mountains Colorado
Is this year the restoration of the car then? Starting in October?
Great story! Glad it all worked out.
Right down the road from ya all that time.
Ohiowoodchuck
Yes sir actually he wasn’t able to get it in till December. He got behind on another couple of small jobs so it was delayed. He went full bore on it though once it rolled in the bay. Also yes, the car was within 30 minutes of my house the whole time. Except when it went to down south and brought back up here.
Ohiowoodchuck
That's quite the stack there!
img_4002-jpeg.142342
Also that wasn’t all of it. They forgot to put the tail panel in there plus once we got farther in to it, we realized the rear frame rails were better off replaced than patched. So I had another order about half this size come in.
heminut
Deming, New Mexico
Great story! I'm looking forward to following this restoration. Please try and post pics as it goes on. Are you considering building a small block engine similar to what your dad built to go in the car?
Ohiowoodchuck
Believe it our not, I already have a 340 at the machine shop with brand new w2 heads and intake. Went in for a brand new build. Going roller cam and everything this time. The 340 had the standard j heads on when I picked it up though. It should be a pretty healthy motor.
Ohiowoodchuck
I thought I would post this picture just for laughs. This is joint is where the cowl meets the floor pan and the inner hinge panel on the passenger side. Notice the amount of seam sealer that was applied from the factory. The sealer had to be at least 1&1/4 wide for a good length up the seam. It just intrigues me on how crudely built this cars were, but it just goes to show how many different hands were involved on the assembly line back in the day.
Ohiowoodchuck
Back to the car. So the first order of business was replacing the firewall and upper cowl. The original firewall had a few poor attempts at some patch work. We really really wanted to save the upper cowl because of the body number stamping in and we tried every way possible but the metal was just too badly pitted to try to save. Even with today’s technology, I was still worried about some bleed thru or a hole just showing up and then deciding to go back in and replace it. We really didn’t want to do the same job twice. As full disclaimer to my build. It’s not a Barrett Jackson build or as nice as some of the other builds I’ve seen on here but I am extremely happy on how it’s turning out and the fact that I get to save my dads car is the real satisfaction in this for me.
Ohiowoodchuck
Save the cowl number. Tack weld on or epoxy. Or drill a hole and screw it on.
We did save the number. Cut out a large section of the cowl with the number on it. I just didn’t think it would be right to cut up a new cowl and weld it in there. Didn’t want people to get the idea I doing something sneaky even though my plans are to never let it leave my sight until death.
I think to attach it to the car somewhere somehow is the right thing to do. It show you took care to preserve what was left.
Ohiowoodchuck
Next we started on the back of the car. Got the trunk pan and drops off out and that’s when we discovered we missed some bad spots in the frame rails. If it was just one small spot I wouldn’t of worried about it but because it needed theee repairs in one rail and two in the other, we decided it was best to just replace both of them.
Ohiowoodchuck
After the rear frame rails were back in and we test fitted the rearend again and checked all measurements, which everything was good. We moved on to the trunk pan and drops off I must say we was really impressed by the fitment of the amd parts. At this particular time there was very little modification if in to get the parts in. We went ahead and replaced the inner and outer wheel wheels while we was in there. Of course the outer’s were bad and the inners could have been repaired, we figured why come all this way to not do it right.
Ohiowoodchuck
After the trunk pan was finished we went on to do the final install of the full quarter skins. I got a little out of line if you look at the last two pictures of my last post you can see the seam sealer was already installed and the new quarters were on already.
