Duster256
I've seen discussion on FABO, FBBO and FEBO that the OEM trim rings for 14 x 6 OEM rallyes are the same as for 14 x 5-1/2 rallyes, with the trim ring measuring approx. 2-3/8" vertically from tabletop to top of trim ring lip (P/N 2944424?) and so when installed on a 14 x 6 rallye that there will be a small gap of about 1/4" or so between the bottom of the trim ring and the wheel.
Below is a photo of what the owner says are OEM 14 x 6 rallyes with OEM brushed trim rings off of his '72 Challenger. Notice how the bottom of the trim rings sit nearly flush against the wheel, without the gap at the bottom of the trim ring seen on some OEM 14" rallyes. Do the rings in the photo appear OEM, and if so are they in fact deeper than P/N2944424? Inquiring minds want to know!
Thanks, Dave
Thanks, Dave
