FOUND !973 Challenger parts needed
terrywalker
Be aware the 73 Challenger had a 2 speed wiper motor as well as a variable speed wiper motor available. You probably want to go with what you have for linkage. The insets and console plate are available as reproductions as far as I know.
T Walker
bamarallye
Huntsville, Alabama
T Walker
I haven't seen them listed anywhere yet.
terrywalker
https://www.classicindustries.com/shop/1971/dodge/challenger/parts/?q=MD4002
New ones for console are available. Used ones are cheaper but usually not as nice.
If you have the door panel inserts and just need the woodgrain see this:
ME1041 - 1970-74 Dodge Challenger; Door Panel Woodgrain Insert Set; RH and LH; Pair
If you need the metal insert, just not the woodgrain material, there's several sets on ebay for sale. Search 1970-74 Challenger door panel woodgrain inserts if no one has them on here. Used bring $160 and up for a pair.
Terry W.
Mr Cuda
North of Seattle
I just wanted to make you aware that the fratzoid has to be removed to apply a new wood grain. I have not done that before, and the pot metal emblem is pressed and peened on the backside.
Careful trimming of the spread metal, but leaving a post to apply some JB weld to the back? IDK?
Or re-peen the remaining post
Just wanted to inform you.
bamarallye
Huntsville, Alabama
I'll figure something out
terrywalker
See, parts you need are being listed by the owners on here. Just let them know whether you need a 2 speed or a variable speed wiper motor now and they can set you up.
Terry W.
