Prw 3244012 rocker set/push rod measuring
STROKERCHALL
CANADA
I bought this set off or amazon.ca. Terrible experience! They were supposed to arrive in 2-3 days, arrived in 10 with 2 updates the whole time, missing one big hold down and got an extra small one, one stud didn’t have a groove for a flat screwdriver to tighten. One hold down nut won’t thread all the way on!
Push rod measuring advice from Duanne Porter.
Back off adjuster all the way out, thread back in one full turn. Lifter on bade circle, adjust push rod measuring device until zero lash, use a calliper to measure total measurement plus 50 though for preload
Measurement 9.328 + (50 thou) equals approximately 9.375” total length
Correct?
Looks right to me .
I would use Smith Bros for pushrods out of Bend Or , you will have a good experience , make sure you know your spring pressures so they can build them correctly for the load .
Looks right to me .
Thanks, I will never recommend Hughes after my phone call this morning!!!
I will contact Smith Bros👍🍺
Looks right to me .
The one full turn on the adjuster Duane suggested gives me 1 thread out
I have built lot of engines over the years I would order pushrods the way you measured them .
Generally I use solid lifters rather than hydraulic .
