craigbred
- Joined
- May 9, 2019
- Messages
- 17
- Reaction score
- 7
Hi All,
I finally took the time to post this. When I was deciding what parts to buy, I got a lot of helpful info from you guys. Anyways, here is what I settled on, and some of ongoing issues.
My buddy and I are not professional builders, but my buddy has put quite a few together over the decades. I have only put a few engines together in my life. Some of my comments are sorta notes to myself, so please take them as just rambling. This is going into my 71 Challenger R/T I owned for 43 years. Yes, my mom and dad left me buy this car in high school, but it only had a 340 in it then.
My hopes are that this engine will last 30 years and 30,000mi. That is the tough part. Listening to all you guys on the internet talk, I would like to have the 650hp, but I want it to last 30 years too!!! For the last 30 some years I had a 440 in the car. I freshened it up without boring it back in the ‘80s (no money for that or new pistons), closed chamber iron heads, 284/484 cam, 12.6sec at the strip. I drove the car into the garage last spring when we pulled the 440.
I hope to get to the strip next year.
I have many thanks to all you mopar guys for all your posts over the years. Many of the details for my build comes from the Ebody, Abody and Bbody sites. I’m not a member of the A & Bbody sites, but I guess I should join so I can post this there too and thank those guys.
Well, here’s the build:
1971 440 block
The boring and decking was done at a respected machine shop.
Line bored main crank journals.
Bored +.030”, to 4.350”
Decked to have piston below deck .005” (in theory)
440Source stroker kit - 505:
6 lb. lighter crank option - 4.25” stroke
+.030/17cc dish pistons (I did not cc the dish)
Total height of piston I measured 2.639”
7.1” rods
TrickFlow 240 heads - advertised at 78cc. I measured ~76.2cc, after grinding/opening up comb. cham. above spark plug, ~77.5cc
Comp Cams tool steel retainers (to save 10 grams of weight). After feeling how heavy the lifters and push rods are (I forgot to weight them and now they are in the motor), I wonder if 10 grams means anything??
Cometic head gaskets, C5462-036 = .036” thick, +.060” diameter to bore. (Not the C5461-036, +.030” to bore, because that gasket is right even with the TrickFlow240 valve pockets and could cause a hot spot.)
Lunadi Roller Hyd. 247/251deg @ .050”, 112deg LSA, .563/.565”, 4deg advanced.
Morel roller lifters.
Harland Sharp 1.5:1 rockers with geometry for the TrickFlow heads (per TrickFlow and Harland Sharp).
Smith Bros. 3/8” pushrods. ~1 thread exposed in rocker adjuster after .030”hyd. lifter preload (about 7/12th of a turn).
6 qt “hemi” pan. Mopar Windage tray, ½” “Hemi” oil pickup.
Stock oil pump with “extension plate”, to allow the long rotor. Higher-pressure spring. Oil passages around pump opened up to match block.
Oil pressure is 55 – 60psi running the oil pump with a drill, 80degF, 30 wt oil.
440Source Girdle.
Torker II intake, port matched to heads and opened up as far in as I could reach up the runners. After installation, I believe I should have taken more out of the floors of some of the runners, noticeably #6 (I could look into that one real easy), but there was no way I was going to stop assembling and start grinding again at this point.
1” tapered hole spacer, 4 into 1. Spacer die-grinded to match intake side. (The 4 holes on the carb. side were good.)
870 Vac. 2nd Holley 81870, 4 corner idle, man choke. Per David Vizard’s Holley book, I cleaned up venture flashing, choke horn edges, butterfly shaft, butterfly screws, and removed the unused squirter mount in the secondaries. Per the book, I estimated 950cfm.
TTI 2” to 3.5” headers.
Current 2.5” full exh. with X, Flowmaster Super 44s, but hopefully 3” within the next year. Mufflers will remain in the very rear of car next to gas tank. New Mufflers will be straight through style, prob. Dynamax.
MSD 6AL, 6425 Prob. Set rev limit at 6600.
MSD Blaster SS coil
Wide Band air/fuel meter, AEM. Bungs in both collectors, so I can check both sides.
Compression 10.9 +/- .1 (cylinder to cylinder variation because of different piston heights)
Quench: .037” - .043” (different piston heights)
I find measuring this is a challenge. I don’t know how much variation is normal from cylinder to cylinder. There’s different piston rock (both up and down AND front to back). The height of piston in the bore varies too. All bearing have assembly lube, pistons have been oil dipped. The machine shop decked the block to have the pistons .005” below deck (mathematically, but not installing the rotating assembly).
With our BEST EFFORT measuring methods (but not professional grade), we measured piston rock at TDC (on intake man. side of piston). The avg. is what I am calling piston to deck height. Adding in .036” head gasket, I have a quench of .037” to .043”, I guess, ignoring piston rock, and only measuring 4 of the 8 cylinders.
#2 +.002” to -.004” avg. -.001”
#3 +.001” to -.015” avg. -.007”
#5 +.002” to -.011” avg. -.0045”
#8 .000” to -.006” avg -.003”
#8 front edge of pis. -.004 to -.008” (avg.-.006”) back edge of pis. .000 to -.006” (avg.-.003”)
On a previous day, we did a QUICK ROUGH CHECK of piston to deck height measuring mostly the “front and back” of the piston, as close as we could to being above the wrist pin (near the piston’s valve relief, on the quench pad of the piston). I suspect the pistons were NOT at perfect TDC for these measurements because we just eye-balled TDC on this day.
Measured close to the piston center, above wrist pin piston intake side, piston rocked up
#1 -.008”
#2 -.006”
#3 -.006”
#4 -.006 , -.008” (front & back, but without rocking the piston)
#5 -.004 , -.007” (front & back, but without rocking the piston) -.0015”
#6 -.006”
#7 -.006 , -.007” (front & back, but without rocking the piston)
#8 -.006 , -.009” (front & back, but without rocking the piston) -.0015”
SO, after all this measuring:
1. Cylinders #2 vs #3 have a .006” difference in piston to deck distance??? Crank, rods, wrist pin height???
2. Pistons have a .001” to .003” tilt front to back.
3. Piston rock at top varies from .006”(#2&8) to .016”(#3). Poss. #2&8 had more of oil behind the rings preventing easy rocking??
4. Some pistons rock with my fingers noticeably more than others (#3 was the most)??? More oil behind the rings of some?
5. Will .016” rock cause piston slap noise?
6. When a piston heats up, how much less does it rock/expand?
7. Doing a quickie micrometer check of the bores, they all measured the same, (we suspected #3 &5 were bigger, but we could not get the mic to read bigger on them bores). We did not measure all the pistons before installing, but the 2 I did measure were both 4.345” on the skirts, but I did not measure anything else on the pistons.
8. Quench COLD, with all the piston rock, could be as low as .034” and as high as .051” (but prob. Less with hot pistons and less rock?).
9. I am hoping to get away with 93 pump gas, no octane boost. I’m afraid I’m cutting it close. Time will tell…
10. Cyl. To cyl deck height difference is .006”: How well machined is rod length, crank journal, piston pin height, squareness of all the rod holes & piston pin holes, and crank journals, left deck vs right, MY measurement accuracy. And finally, does it even matter for a hobby motor?
11. Perhaps too many measurements – Confucius say, man with one watch always know exact time, man with two watches never quite sure…
Startup on engine start stand:
1. Set advance limiting plate in the 14 deg slots, but advance seemed to swing from 15 to 33, 18 deg swing? Need to figure that out.
2. Around 9” vac at about 900 rpm. Too soon to get vac. numbers. It would keep idling down to 600! YEA.
3. Slowly revving it up, it would smooth out at 2000rpm and above, then slowing back down, it would start “roughing up” at 1500rpm and below.
4. Oil pressure – Ricky’s gauge, un-dampened, 70psi cold, 55ish warm (all fast idle and above). About 15psi flutter=more than normal. Removed oil pressure spring from pump and discovered a “sleeve”, about 1” long, inside the coil spring. The sleeve looked a lot like a thin wall roll pin. Ricky’s Hemi oil pump did NOT have this sleeve, so we removed it. Then 80psi cold, 65ish warm (fast idle and above), 25ish at 800-900 idle. The run stand’s gauge read about 3psi higher at all pressures.
5. The rocker’s oiling seems less on the drivers side. It seemed like not enough oiling at first, but after removing the sleeve and getting an extra 10psi, we thought it seemed ok, but surely not an over abundance of oil.
6. THEN the OIL LEAK. Rear main seal
Drain oil, water, disconnect everything, lift from start stand, attach to std. engine stand, remove oil pan, windage tray, girdle, rear main seal, huhhh. Machine .015” off the seal cap. Another new Felpro end seal kit. Black silicone under the seals, and every where else. Re-assemble and re-test. GREAT, OIL LEAK FIXED!
In the Car, finally! We are having our share of issues, so here goes:
I have to end, my letter count is too high
1971 440 block
7.1” rods
440Source Girdle.
MSD Blaster SS coil
#1 -.008”
#2 -.006”
#3 -.006”
#6 -.006”
