Wiring hangers and clamping.Question
Flathead31coupe
Indianapolis
Where is the best place to find a diagram for a 73 barracuda. engine compartment that shows the routing of the wires. And the individual hangers that are needed to be used as it would have came from the factory.
Thanks.s
What year are you looking for specifically? Although basically the same they did change some over the years.
The engine harness runs along the back of all engines, then the inside of the passenger valve cover. Then from the back of the alternator to the horns and washer bottle.
The light harness runs along the drivers side inner fender. Then across the front of the core support. It's all self explanatory, wants you start seeing the holes and clips.
View attachment 146871View attachment 146872View attachment 146873View attachment 146874
Cool thank you very much...
Is there a picture or a diagram as to where all of The Wire fasteners?Or wire straps go on the firewall and interfenders that hold the wires.In place....
You may be able to find some diagrams in a factory shop manual. Well worth buying or downloading if you don't have one. Here's a pic of a 70 Challenger (not mine) which should also help. I think at least one of the bigger black plastic clips changed location along the back of the firewall by 71 and there may be other changes over the years but many should be the same as well.
You may be able to find some diagrams in a factory shop manual. Well worth buying or downloading if you don't have one. Here's a pic of a 70 (not mine) which should also help. I think at least one of the bigger black plastic clips changed location along the back of the firewall by 71 and there may be other changes over the years but many should be the same as well.
Thanks.s
That level of detail was available in the engineering diagrams from that time. Some years and model lines have been published as assembly manuals of late. Haven’t seen anything specifically for E-bodies for any years as yet, closest you will come to a ’73 E-body would be a diagram for a ’72 B-body. It should be pretty close in the engine compartment.
Awesome info ty
