Cuda Decal
KennyCuda
A very good friend on mine has a 1974 Cuda hes the original owner he ordered it new from the dealer and recently told me the car use to have a small decal on the drivers side valve cover that said Windsor engine plant well in the late 70s he took the decal off and now wants to try and get one. Does anyone know the decal im taking about and do they repo it.
he threw it out back in the 70s anyone have a picture of one ?
Perhaps the graveyard car guy who recently found 2 never delivered '74 cudas will post an engine bay shot or might have a picture.
By chance was it anything like this.
Thats an idea to trying contact them-- and thanks for posting the picture but my friend said the decal was long the think and it was green with black lettering and all it said was Windsor engine plant like the last line of your decal but said Windsor instead of mound road
back in the 70s Chrysler had a plant in Windsor Canada and thats where his engine was from probably rare they didnt make alot of 360 cudas
Below on Left (driver) side, front of block just under cylinder head. W = Windsor, Ontario Plant (318-340-360). P = Premium Fuel Recommended. ✠ = .001″ Undersized Crankshaft Journals (Oversized Bearings)
Decoding Additional Symbols & Stampings:
A
= .020″ Oversized Cylinder Bore
B = .010″ Undersized Main & Rod Bearings (Oversized Bearings)
C = Special Crankshaft & Pistons
E = Cast Crankshaft
H = Standard 4 Barrel Carb
HP = High Performance
LC = Low Compression
OS = .005″ Oversized Valve Stems
S = Service Engine (found on Warranty Blocks)
sP = Special Engine use Premium Fuel (found on T/A 340 Engines)
WT or TW = Water Tested (normally found on Hemi’s & Warranty Blocks)
X = Oversized Valve Guides
2 = Second Shift
♦ = .008″ Oversized Tappets
✠+X = .010″ Undersized Crankshaft Journals
