70 Challenger with rallye 15x7
fstuff138
Brazil
anybody running 245-60/15 on their stock rallye 15x7 wheels on a slighlty lowered front? any rubbing or fitment issues? could you please show me your setup? im between 245 all around or 235 front and 245 back ou 235 all around.
I run 235/60/15's on the front with 5 different sets of wheels and tires with all stock front suspension and ride height with no rubbing issues. The 2 other sets are currently on other cars.
A lowered front end is a generally a bad decision.
Deep street dips, steep crowned driveways, parking lot cement tire stops.
Ground clearance, alignment, suspension damage from bottoming out every bump. Unless you use dropped spindles. for alignment and suspension bottoming.
Especially with headers.
All cars pictured are either Factory ride height or taller.
Any time you go away from Factory Specs on anything, there will be consequences of some kind.
A lowered front end is a bad decision. Ground clearance, alignment, suspension damage from bottoming out every bump. Unless you use dropped spindles. for alignment and suspension bottoming.
Depends on the set up. My blue 70 Challenger sits lower than all of my other cars and I have the most clearance on this car with headers, an 11 quart oil system, deep trans pan and 3-1/2" exhaust using a tubular K frame with coil overs.
I'm running 255/60/15 Coopers on 15x7 cop wheels on my 70 Challenger. Stock height. Been that way for about 12 years now.
