Driveshaft part number
mapletonmopar
Minnesota
Hello,
Ive recently pulled the drive shaft out of my challenger T/A and stripped the paint off of it. I found a part number 2883600. Ive been unable to locate this part number in the 70-74 parts book. It has the correct 7290 u joints and measures about 45.60" center of u-joint to u-joint. I believe it should have a 2883782 which would measure out at 45.85" per the part book. I don't believe this difference in length would really matter but I am curious what car this is correct for? It also has a H9 stamped near the part number that could be a date code? Thanks for any help!
The 2883600 is the part number for the tube/drive shaft, 2883782 is the whole assembly with U-joints and yoke.
Thanks for the info, do you know if the driveshaft would have had the whole assembly part number stamped anywhere? Or possibly it was an ink stamp?
The part number and date codes are stamped about 24 inches from the rear joint. Here's a pic of the original from my T/A with the 2883782 number with a C 70 date code. Trans Am cars (and some others I believe) had 7260 u-joints in front and 7290 in the rear.
Thats interesting they would put different size u-joints in them...do you by chance have the length of your driveshaft?
It’s in the car now, but when I was restoring it I measured and it matched Galen’s White Book description.
