Front Sway Bar...?
Oystercopy
Hey guys...
About 5 years ago, I put a rear sway bar (Hotchkis) on the Challenger. Helped a lot with cornering.
Now I'm considering putting a Front Sway Bar on it, and wondering a couple of things:
1) Were the holes there to install a front bar on EVERY car? I've not been under there in a good while, and I've never installed one of these before. I understand greasing up the bushings is paramount with these things.
2) Is there really a difference between brands? I'd like to use another Hotchkis, since it would be nice if they matched, but they are about $450-$500 for that kit, and I've noticed that the Addco and the QA1 kits are about half that price?
Any help appreciated!
OC
How do you know that? Does anyone have a picture, by chance?
I couldn't find any pictures online of what it should look like, but it says that i have to weld brackets onto my control arms if they're not there? And that the geometry of where to put them is a very important step (whatever that means!...LOL)
The original Sway Bar set up works really well and are easily sourced. I added the tabs to the lowers without removing the lowers. Picked up a set of tabs and welded a back plate to them. Drilled a center pilot hole in the back plate of tab. Held it in correct place on the lower and used it to drill a pilot hole into the lower. Then drilled out both for high grade bolts and lock nuts to attach them. The upper lip on the lower interlocks with the tabs preventing them from moving. Attached are a few photos for a better understanding of my Desert Rat engineering. I know I could have had them welded on too.🌴
Thanks for all that guys. I thought this was going to be a bolt on thing, but I guess not. I don't weld, so if it requires any of that, I'm going to have to hold off for a while, as I don't have any way to do that right now.
OC
I had the back plates welded onto to tabs by a welding/muffler shop. Then bolted the tabs on with high grade bolts. Everything on the original sway bar setup bolts on without any other welding. For street application it has worked great for me. Good luck 🌴
You notice any rotation of that bracket, lot of force there?
Maybe a longer back tab and 2 smaller bolts would eliminate that possibility?
The tabs have a notch at the top that lock into the lower arm. The lip at the top of the lower fits in that notch snugly and aligns the tab for proper placement. This fitment prevents the tab from rotating or moving after being bolted on. High grade bolts can handle more than the car weighs and would have to snap before the tabs moved. Very solid for street use.🌴
You need to balance the front & rear diameter , Hotchkiss would match the rear & would be the best choice , or a matching diameter to the Hotchkiss bar
Depending on your preference of factory control arms versus aftermarket…
Inspect all of your front suspension bushings, tie rods, etc. including the lower control arm bushings at the K-member. If bad then the arms need to be removed to replace the bushings. Good time to add/weld reinforcement plates and sway bar tabs, if missing.
Alternatively, upgrade to QA1 lower arms with bushings already installed. Stronger, lighter, and sway bar tabs already there.
Plus, you can add the QA1 upper control arms for more positive caster.
An Addco 1-1/8” front sway bar kit is a bargain and has the end links and K-member brackets.
https://www.kanter.com/products/suspension-stabilizer-bar-sway595
OC
Welding the mounting brackets to the control arm is the best method, but not a requirement for use. Some after market bars will have kits for cars with or without existing mounts. Kits for cars without mounts will include a bolt on bracket that attaches with the lower shock bolt. These are very effective at connecting and working the bar properly.
Since you have a Hotckkis bar out back, a Hotchkis front bar is designed to work in conjunction with it while being lighter weight because of its large diameter, hollow design Other bars that are less expansive are usually solid, but will be of smaller diameter, a higher weigh, and provide a very similar rate.
Can you link the bolt on ones? I have a friend starting his restoration in one and this would help him out a bit.
