1970 Barracuda trunk floor support measurements
BTekulve
United States, Indiana
Looking for dimensions for where to put the trunk floor supports off of the frame rails (front and rear measurements) or distance between them if they are centered from the fuel filler hole? Are they parallel or do they taper in or out at all? Any help would be appreciated. Thanks
This image is not my car, but shows what measurements I am in need of.
If you would measure the gas tank where the straps go. It would be the same. Center of straps. The gas tank hangs from there. That's what I thought you meant but a picture explains a lot.
Thanks for the measurements, that's is exactly what I was looking for.
My dad started to restore this car, but he cut the fuel tank, frame rails, and trunk support arms to narrow his rear end for wider tires. Unfortunately, he passed away and now I am picking up where he left off, but I am making it more road safe vs drag racing so I am having to redo some of the work he undid.
Just wanted to make sure you didn't need another picture or measurement.
Please post pictures of what you are working on, we would like to follow along with your progress.
