retired49
hi everyone I have a 1973 cuda sublime green with a 400 big block 30 over and 4 speed manual trans, it is a project I drove this car last summer during winter I pulled engine rebuilt it. to finish motor it needs a cam, carb,spark plugs , I took 727 auto. out and put a 833 from an e body in , the pedals are in the floor hump has been changed to finish the 4 speed it needs flywheel,clutch pressure plate, throw out bearing ,z bar and bracket . I took the rear end out to change ring and pinion, I put new bushings in springs and new brackets on fron of springs , to finish the rear end out it needs new ring and pinion the old one was a 2.73 and it didn't work good with the big block. and it needs a manual shift carpet. besides the stuff I mentioned I have the rest , also it needs a set of front tires I have steel rims all the way around and a new set of m/t street slicks for back ...I am located near port huron Michigan and I am asking 9500.00 for everything ,,pm me with questions or I will pm you back my number. thank you for looking
