302 Heads on a 318
Fordication
Houston, Tx
Have a chance to get a set of these cheap. 302 heads. Should I bother? The 360 is going to be set aside until I have a chance to move some things around. I am about to start selling cars so this has to be put on hold for awhile. Have to get the Cougar out of my garage and a Harley too. Need more room.
Assuming they're in decent enough shape where a fresh valve job will revive them (no cracks or broken pieces), the 302 heads are great to run on any small block (273, 318, 340 & 360).
302 heads flow less or the same as what you have. 302 Heads are very prone to cracking. Nothing wrong with 675 head castings. I scrapped a lot of 302 heads to find a couple good pairs, only to have them sit on a shelf.
Yes some do crack , easily fixed !
The 302/308 swirl heads flow extremely well . the 308s will easily flow better than X or J castings , the 302s work well also
302 heads do not flow well in stock form. 308s will flow slightly better than X or J castings, but I gave up on finding any uncracked 308 castings years ago. I will not start with cracked head castings, I put too much time and money into my heads. X or J heads are fine with me. I am not a "Class Racer".
I have a pair of 302 heads on a 318 with 1.88" intake valves added. Minor pocket porting. The real reason to add the 302 heads is the closed combustion chambers. This will raise compression about a half to 3/4 point. That's not bad if you're working with a stock bottom end on a 318. It offers a low budget option to many.
Yep and he threw in a comp cam, lifters and push rods for 100 bucks.all aftermarket.
Gotta love cheap horsepower! And the little kicked around 318 certainly responds to modifications! Built right, they're hard to tell from a 340! Especially below 5500 rpm!
Well I learned something this week. Mopar heads are heavy as hell. I picked up the heads and he threw in a bunch of other parts like a comp cam and comp cam lifters and after market push rods, aluminum timing chain cover and water pump. All new. My garage said the cam is perfect and its going in along with the double row timing chain he gave me. The heads are also perfect. I heard a video of what it sounded like when it was in the other engine. It was awesome. Now what I learned. The weight of the box was 140lbs. Could not put it on the airplane and UPS wanted $500 to ship it to my house. So, I had to use my rental car and drive 9 hours home from Montgomery to Houston to save money. Still waiting for Enterprise to tell me what that cost me but I am sure its cheaper than $500. Good thing I have tons of points just in case. Anyways, its all going together this week along with a new Edelbrock carb and intake. Cannot wait.
Wait till you have an 833 on your chest trying to slide the snout in the pilot bearing without a transmission jack...glad you're getting cl9ser to having it all buttoned up.
I built my 318 based off the junkyard jewel article from hot rod. I did use aluminum heads from speedmaster instead and got them during their big sale at thanksgiving. The price of those on sale just made a lot more sense than messing with old iron heads. Since the heads have bigger chambers, I did go with the KB pistons. I also went with a retro roller cam, so I didn’t have to worry about any lack of zinc in the oil, quite a bit more money but I think it was worth it. Car is still in the build stage, maybe next year it will be done. I am hoping for over 400hp from the 30 over 318. I will use a thermoquad carb on a weiand 4 barrel intake. I need to use an intake close to stock height for the shaker setup. Here is the article…. 318 Small Block Build - How To - Hot Rod Magazine
I made a correction.. I DID need to use the KB pistons.
