318 Engine Brackets
Kevineng
Minnesota
Plan on mocking up the engine on the car, but I need engine brackets. Its a 318 going into a 72 challenger. From the looks of it, these brackets are hard to find. I can only find one aftermarket supplier that may have the set that will work, Schumacher '66-74 B,C,E-Body 273/318 or 340/360 Replacement or Upgrade Kit (mancini racing sells it for them too Engine Conversion and Replacement Kit). Anyone had experience with this particular bracket, does it fit? Id hate to fork out 200$ if they dont work.
There is definitely a difference between the 273/318 and 340/360 on the driver's side. So you certainly need to make sure you get the 273/318 brackets. Except for factory original, I don't think there's anything better than Schumacer's motor mounts.
Mr Cuda
North of Seattle
Deal of the week.
Mounts, and I will provide factory k member through bolts, and 6 mount to block bolts.
Plates have the mount to plate nuts.
$80 shipped usps flat rate.
($60 + 18.95)
