LS1K5
I have 2 1971 318 blocks in good condition, one is the matching numbers block to my car and the other is from a dart. I'd like to build one or both of them eventually, my matching numbers block needs a crank but ran perfectly and the other had low compression and lots of blow by. I was thinking of just swapping cranks and keeping the matching numbers  engine completely stock but I'd probably never use it even though I have all the parts to make my gran coupe as original as the day it rolled off the assembly line, I doubt there is much value in that and the car wasn't much fun to drive when it was 100% original. I have several sets of late 60s early 70s 340 heads and a matching 4 barrel intake, I was thinking about putting in some forged dome pistons to up the compression on an all cast iron engine. I was also thinking of using a scat 3.58" stroke 318/340 crank with some 1.72" compression height stock type pistons but I'm guessing they would probably hit the counterweights on the crank, what are some of the things you guys have done with 318 blocks besides a 4" stroke rotating assembly?
