My plan is to build a stout rowdy 340 for street and some track use. It will be backed by a 904 and rear gears are yet to be determined. The rotating assembly is balanced. Pistons are SRP 142068 flat tops with 2 valve reliefs. Comp ratio (70cc) 9.2, (60cc) 10.5.
Heads are freshened 340 X with mild port cleanup and upgraded springs and milled. My question is the following, should I switch to Magnum heads (benefits?) and of course what cam is recommended. with my current budget aluminum is out of the question. Thanks for any help!
