The number you supplied is for a 71 model year, does it matter what year, are you wanting to be date correct? I have a 70 manifold #2951736, early October 69 date code from a 440 HP with the AVS carb
There were 2 common intakes, the 350 horse motor with the Holley carb, and the 375 horse magnum motor with the AVS Carter carb. I don't believe there was much if any difference between the 69-71 440 RB Magnum intakes. They never made a 71 4bbl with a shaker, I believe all 440 E bodies were 6 pack equipped for the 71 model year.
3512501 part # is not listed for a 71 E body with a 440, it's listed for B & C bodies.
yes I am interested, can you look into sending it out by Loomis (Purolator) and I will give you a CC to charge it all to. Just call my at 780-706-4578 for numbers.
I have the -501 intake - as removed from '71 TNT engine. In Southern BC you can hardly give these things away so valued at only about $75. (CDN). Only good for someone doing a numbers resto.
