Gator
- Joined
- Dec 21, 2010
- Messages
- 9
- Reaction score
- 0
ok here it is got my 383 put together and can only set total timming at 24deg at 2000 or it wants to run hot . I installed a new mopar performance dist made sure cam was timed dot to dot on crank installed new E3 spark plugs am running 93 octane gas . Build is as follows 383 bored 040 kb 400 domed pistons comp cam 280h 452 heads new eddy 750 carb alum high flow water pump and housing new mopar dual plane intake manifold new hooker headers new summit 3000 stall converter with rebuilt tci trans i havent drove car yet as unsure what to do build was recomended by a friend but friend bailed after getting parts been asking questions and some have said defective distributor others say i need racing fuel cause comp is too high with cast heads not enough fuel through carb needs bigger jets needs alim heads so i have no idea which way to go this was built for my over buget project so funds are really getting limited now any help would be apreciated
