440 and 400 engines
wannadrag
1973 steel crank 440 non HP,will need a rebuild.Crank and bore are both Std. yet.906 heads with a iron intake.It is apart.
1976? 400 this one also needs a rebuild and is also apart.this one is currently 030 over and I and guessing the crank was turned also.906 heads,unknown aftermarket cam and deep oil pan.
Most of the parts are there for assembly $500 firm for the pair Located in central WI near Waupaca and will trade for BBP 15" ralleys with centers and trim rings,383 or 440 airgrabber air cleaner assembly or a nice 70-74 Challenger twin scooped hood
bob carter
What would you charge to deliver the motors to me , I live in oblong il 62449 ? If you would deliver them to me , I would buy them .
DetMatt1
You’ll need to start a private conversation with him as he probably doesn’t check in here often.
wannadrag
440 is gone,still have the 400 and negative on driving 4+ hrs one way so you can look at it
