dentwizgen
- Joined
- Sep 4, 2010
- Messages
- 21
- Reaction score
- 0
Hey fellas,
I have a 70 challenger with a 440 6 pack set up. I bought the car as a turn key car this summer and it runs pretty good. The guy told me that the only mods was the biggest cam that mopar makes. Not sure of the lift.
Here is the problem.
When I start the car is seems to run fine about 1000 rpm then after it gets warmed up, it will runs at higher rpm then slower rpm. Bounces all around . If I turn off the car for a little and then restart it, it runs at a lower rpm say, 800 or less then high again. I looked for vacum leaks , tighted all the gas fittings but still can't seem to locate the irregular ideling.
I am not sure if the carbs need rebuilt.
When I got the car, there are 3 feul lines that come from the rear. The main gas line, the return line and also a vent or over flow line. The over flow line was caped off. Could this have something to do with it?
Sometimes , even after that car is warmed up, it will not start right up. I have to pump the gas pedal several times then is slowly starts ?
Any ideas ?????
I had a friend check the timming and he said it was fine.
Should I have the carbs rebuilt. They are original to the motor. Real V code car. Elderbrock
Any ideas ?????
